 Post subject: email checker
PostPosted: Mon Apr 02, 2012 5:18 am
how i can use email checker for yahoo mail?
wath settings should i use?
thx
 Post subject: Re: email checker
PostPosted: Mon Apr 02, 2012 3:32 pm
As always, Google is your friend. If you search Google for "yahoo pop3 settings" (without the quotes) the first page you run across is THIS.
It actually tells you what settings to use for Yahoo, Hotmail, Gmail, MSN, AOL and more. Disregard the SMTP part since that is for sending mail and the Email Checker does not do that.
However, I've also heard that you can only access Yahoo mail by POP3 (POP3 access is a requirement if you want to use the Winstep Email Checker) if you have a paid account.
PostPosted: Mon Apr 02, 2012 3:46 pm
Is email checker working for normal yahoo.com mail acc ? i did the settings and nothing...i realy need this,
do i need paid account??? wath is that meen?
thx
PostPosted: Mon Apr 02, 2012 3:54 pm
Hey, don't blame me, blame Yahoo! :D
Looking at the 'Offline access with POP' bullet point in THIS page, it seems they do require a Yahoo! Mail Plus paid account to access Yahoo mail via POP3 (i.e.; for non-webmail access, as in you want to access your Yahoo mail using a normal email client such as Outlook, etc...).
PostPosted: Mon Apr 02, 2012 3:59 pm
i am not gone blame u :)
so that is the only way...
ok...thx
Users browsing this forum: Amazon [Bot], Google [Bot] and 71 guests
