 Post subject: Big Problem
PostPosted: Tue Mar 27, 2012 2:46 pm
I have a big problem with the latest version of the Nexus dock, after resuming from hibernation there is only the dock, no icons, I have to mouseover to make them appear. What do you suggest Jorge? Reinstall the previous version or what else could I try?
Waterworld
 Post subject: Re: Big Problem
PostPosted: Tue Mar 27, 2012 2:52 pm
Hmmmm... Do you have the dock set to auto-hide?
If so, what auto-hide animation are you using? The old, normal, slide animation?
PostPosted: Tue Mar 27, 2012 3:50 pm
No, I have set it in normal mode
Waterworld
PostPosted: Tue Mar 27, 2012 4:01 pm
So, what you are telling me is that the dock background shows, it's just the icons that are not visible?
Can you post a screenshot of the problem, please?
Also, does it matter how long your laptop has been in hibernation?
PostPosted: Tue Mar 27, 2012 6:51 pm
yeah, just no dock icons, any hibernation time does not change the situation. Also I notice a reactivity slowdown of the elements on the dock. I solved right now reinstalling the previous version, now everything work better than before :mrgreen:
Waterworld
PostPosted: Tue Mar 27, 2012 7:15 pm
What is it with people re-installing the previous version instead of helping solve any problems in v12.2, which has a ton of new features?
Ok, be stuck in v11.10 forever, see if I care. lol
PostPosted: Tue Mar 27, 2012 7:36 pm
I agree with you , but on my pc the 12 worked very badly, and it was pretty much a step backwards compared to version 11. I also tried to reinstall 12 before replacing definitively with the 11, but nothing fortune
Waterworld
PostPosted: Wed Mar 28, 2012 6:19 pm
There's a new release of v12.2 (your Winstep Update Manager should pick it up within the next 24 hours, otherwise just do a manual check for updates) that fixes some (or all) of the problems. Give it a try, then please let me know.
PostPosted: Thu Mar 29, 2012 6:32 pm
Ok I'll try this too
Waterworld
PostPosted: Sun Apr 01, 2012 7:59 am
I installed the latest update yesterday and it seems that the bugs are gone, seems to spin smoothly for now :)
Waterworld
PostPosted: Sun Apr 01, 2012 11:14 am
I was wondering if you can set in view menu from the dock, the folder contents by type, as set in Explorer and not merely by alphabetical order, as dock set by default
Waterworld
PostPosted: Mon Apr 02, 2012 6:00 pm
Up :)
Waterworld
PostPosted: Mon Apr 02, 2012 8:22 pm
Not currently, sorry. Also, keep in mind that browsing the contents of shortcuts to folders in a dock via the right click context menu is already something far out of the scope of a normal dock application, and more in the realm of the NextSTART component of Winstep Xtreme.
PostPosted: Fri Apr 06, 2012 8:25 am
update: after a few days of usage of the fixed latest version, everything works fine apart the trash, it is slower in updating full/empty icon and some times emptying it (from dock) the nexus freezes for about ten seconds, then appears normal message to confirm empty the trash, I do ok and everything returns to normal working
Waterworld
Users browsing this forum: Amazon [Bot], Apple [Bot], GPT [Bot] and 105 guests
