 Post subject: I got a few question new with winstep
PostPosted: Fri Mar 16, 2012 2:25 am
Is there a way to add sys tray and running program in the dock? I know the shelf can display both of this but wondering if I can have it on the dock also.
Is it possible to use modules from a different dock in winstep ex. rocketdock or object dock.
When will stackdocklet be available?
 Post subject: Re: I got a few question new with winstep
PostPosted: Fri Mar 16, 2012 9:44 am
1. Sure. You can do it either from the Contents tab of the Dock Properties panel for that dock, or you can right click any icon in the dock -> Insert New Dock Item -> Show System Tray in this dock/Show running applications in this dock.
2. No, 3rd party docklets\widgets are not compatible with Winstep applications.
3. Well, not for v12.2, that's for sure, which is already a MONSTER release. I'm aiming for the release after that, but don't hold me to it.
In the mean time you can use Cris'n'Soft standalone Stacks.
PostPosted: Fri Mar 16, 2012 11:11 pm
Thanks and looking forward to the stack docklet in the near future
Users browsing this forum: Amazon [Bot], Google [Bot] and 61 guests
