Board index : Winstep Forums : General Discussion  [ 86 posts ] Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Want a FREE Winstep Xtreme license?
PostPosted: Sun May 08, 2011 3:03 am
If you only translate the free version of Nexus, you get Nexus Ultimate free. If you translate Winstep Xtreme, you get Winstep Xtreme free. :D
PostPosted: Sun May 08, 2011 4:55 am
In my installation the languages folder contains 3 program languages: NeXuS, Xtreme, Update manager. So if I translate Xtreme I get the Xtreme version license, and if I translate NeXuS I get the Ultimate version, right? (Update manager will also be translated as I read in another thread)
PostPosted: Sun May 08, 2011 10:43 am
No, no. You wished, eheh. That Xtreme folder in Nexus is for the little theme manager executable.
You will have to install the trial version of Xtreme.
PostPosted: Sun May 08, 2011 1:53 pm
OK, got it :)
One last thing: I see there is no Romanian translation. Actually, I am Romanian living in Italy (8 years); would it be ok for you if I make also the Romanian translation?
And also, can the translation use Unicode chars or only ANSI chars?
PostPosted: Sun May 08, 2011 4:26 pm
Provided the translation has quality, up to you - but it *must* be ANSI chars.
PostPosted: Mon May 30, 2011 12:42 pm
I've finished checking my Italian translation and I've just sent an email at support@winstep.com. The translation is for NeXuS Dock as i haven't got time to work on the full Winstep Xtreme translation, so Ultimate license for me.
In the email I've sent there is the download link. In the download archive you'll find a readme file, please read it :)
PostPosted: Wed Jul 06, 2011 8:26 am
Yes, I would like a free license very much. because this stuff is aweeesssooommeeeeeee. haha. but forreal, I do want it, and I would gladly make a theme for it, if I could find a straightforward answer on exactly HOW to do this :(. Itd be great if i could do most of it on Photoshop, but it doesn't seem that way. im just not even sure where to start with this. its annoying and makes me very sad... *sniff*
PostPosted: Sun Nov 27, 2011 5:03 pm
I've finished The Fix, and updating the Finnish translation :) (and also fixed a lot of words) should i send it to your support via email, or attach it here?
- Cheers kynix
PostPosted: Sun Nov 27, 2011 9:52 pm
Send it to Winstep support, please. :D
PostPosted: Sat Feb 11, 2012 8:28 pm
Not sure if the offer is still on but I started to create a theme and was wondering how complex it needs to be...
This link below is to a screen capture (on my site, click to enlarge)... could you please let me know if I'm on the right line....
http://www.phpbbireland.com/kiss2/viewtopic.php?f=3&t=232
Mike
Kiss Portal Engine (Kiss portal for phpBB revamped) Dev Site
PostPosted: Sun Feb 12, 2012 2:48 am
A complete theme skins all Winstep Xtreme objects (the Shelf, desktop modules, the taskbar, menus, hotspot buttons), not just the dock.
PostPosted: Sun Feb 12, 2012 3:10 pm
No problem... I can use an existing theme to show all the necessary files right?
Can you give me an example of one that contains everything and of the right quality?
Mike
PostPosted: Sun Feb 12, 2012 3:49 pm
Check out the KTEK-4D or DarkTech themes.
PostPosted: Sun Feb 12, 2012 3:59 pm
Perfect, thank you...
PS, Great product ;)
PostPosted: Sun Feb 12, 2012 4:20 pm
Thanks... it's about to get much better, with the next version nearing release! :D
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 86 posts ] Go to page Previous  1, 2, 3, 4, 5, 6  Next
Users browsing this forum: Majestic-12 [Bot] and 24 guests
