 Post subject: Win 7 Startmenu appearance
PostPosted: Wed Jan 25, 2012 9:22 am
Hello,
since a few days, im using Nexus Dock as replacement for Win 7 superbar and it works very fine.
But one thing, in a video tutorial of Nexus Dock i'd seen, that, when you click on the build-in start-button, the Win startmenu appears right over the start button, unfortunately in my case it did not, it remains at left bottom side.
But however, thanks for this great piece of software
Nora
 Post subject: Re: Win 7 Startmenu appearance
PostPosted: Wed Jan 25, 2012 1:41 pm
You're using Windows 7... under 7 the start menu position can't be changed (on Vista and XP, the start menu will appear near the Start button on the dock like you saw on the video) or it will start having painting problems as you mouse over it.
This is not a Nexus bug, it's Microsoft's fault that designed it this way...
PostPosted: Wed Jan 25, 2012 4:08 pm
Ooh,
that's a pity. :cry: But thank you for the fast reply. :wink:
Keep on your excellent work
Nora
Users browsing this forum: Apple [Bot], winstep and 17 guests
