 Post subject: couple settings questions
PostPosted: Fri Apr 21, 2006 11:35 am
ok I have 2 very simple questions that I can't find the answer to in the forums/documentation. I'm betting/hoping this is just another instance of looking for my keys that are already in my pocket... :shock:
1) can't resize the star bar. dunno why, just wont let me.
2) can't find where to change the workshelf submenu's to a "verticle list" format instead of a "horizontal icon" menu. If that's not possible then what is the menu bar I'm noticing in some theme screen's that often has "Menu, Graphics, Tweaks, Microsoft, Stuff, Applications" bar with drop downs?
PostPosted: Fri Apr 21, 2006 6:41 pm
I assume you want to resize it vertically, right? S-l-o-w-l-y bring the mouse cursor to the top edge of the NextSTART startbar. When it turns into a vertical sizing arrow, you can left click and drag up to resize the startbar.
For the time being, WorkShelf can only dock to the top or bottom screen edges. There is no 'vertical' layout.
You will have to be a bit more specific than that and point out the URL to the screenshot(s). They are probably NextSTART Hostpot buttons though, or horizontal menus...[/quote]
PostPosted: Fri Apr 21, 2006 10:04 pm
The Start bar is verticle and I want to shrink it's horizontal properties.
You're right those are hotspots in the screen's. Sadly the shelf doesn't have the option I'm looking for.
PostPosted: Sat Apr 22, 2006 3:13 am
But it's going to... just stick with it. :D
Users browsing this forum: Amazon [Bot], winstep and 62 guests
