 Post subject: E- mail checker settings
PostPosted: Tue Oct 04, 2011 1:28 pm
Hi ,
Somebody can tell me how to configure my e-mail checker. would like to activate my account Google. POP 3 or IMAP to use, SSL - must be turned on or not and what to write in the Client window , becouse to get error windows with error message:
"Windows cannot find https://mail.google.com/mail/?shva=1#inbox'Make sure you typed the name correctly , and than try again.To search for a file ,click the Start button, and than click Search ." :?: :?: :?:
Best regards : Tamas
PS: what is wrong :?:
File comment: erreo message
 Profile YIM
 Post subject: Re: E- mail checker settings
PostPosted: Tue Oct 04, 2011 2:28 pm
@tamaspaal
I think the assumption is that you have an application like "Thunderbird" or "Outlook" or "Pegasus" for an email client. You have entered the way you would access your email from a browser-based email client.
Grouch
Windows 10 Pro[x64]
Nexus Ultimate 20.10.1154
Antivirus: Windows Defender
PostPosted: Tue Oct 04, 2011 4:36 pm
There is one reason why this won't work, regardless: Gmail connections require a version of SSL/TSL not supported by Winstep Xtreme/Nexus (in fact, the last version of Xtreme does not even have the SSL option, so you must be using an older version).
The good news is that I might have found a solution in the form of a 3rd party tool, but I am still looking into this.
Users browsing this forum: Amazon [Bot] and 39 guests
