 Post subject: Weather Icons
PostPosted: Mon Sep 05, 2011 4:54 pm
Can I replace them with a different set of icons?
 Post subject: Re: Weather Icons
PostPosted: Mon Sep 05, 2011 5:47 pm
Sure, just use the same numbers/filenames. Remember there are two styles/different sets of icons, so replace the style you like the least.
Also, after doing that, make a backup of the new set somewhere else on your hard drive, as installing a full version of the software will replace the icons with the default set again.
PostPosted: Mon Sep 05, 2011 6:40 pm
How do I know what the file names are? It's hard to tell, for example, "partly cloudy" from "mostly cloudy", etc.
Users browsing this forum: Apple [Bot] and 17 guests
