 Post subject: More taskbar/system tray questions
PostPosted: Sun Jul 31, 2011 11:54 am
Hi
Sorry to bother you again, but I wondered if it was possible to set a Hot Key for the taskbar to appear. I have the taskbar and the dock docked on the bottom of my screen, but if I bring up my taskbar by mouseover, the dock also pops up.
Also, I seem to be having an issue where when I click on the system tray button, the tray appears above the taskbar as it should, but a second system tray briefly flashes up in the top left corner. I'm guessing that maybe it's a hotspot thing, but I've disabled all hotspots bar the first one and it still appears.
 Post subject: Re: More taskbar/system tray questions
PostPosted: Sun Jul 31, 2011 7:52 pm
Sorry, there is no hotkey for hiding/showing the taskbar.
As for the expanded system tray briefly flashing on the top left corner, unfortunately that is a 'by-product' of the way the tray expansion window (which is provided by Windows itself, not Winstep) is moved to the proper position.
PostPosted: Sun Jul 31, 2011 8:12 pm
Not a problem. Thanks for the info, Jorge.
Users browsing this forum: Amazon [Bot], GPT [Bot] and 38 guests
