 Post subject: License Question
PostPosted: Tue Jul 26, 2011 3:43 pm
Hi I just bought Winstep Extreme 1 license havent had time to install it yet though :-) Have to wait till the kids are at sleep.
. The question is very simple can I install Winstep Extreme on my Stationary computer as well as my laptop using only the 1 license I bought ?
Thnx in advance for your time answering this question.
Best regards.
Allan C.
 Post subject: Re: License Question
PostPosted: Tue Jul 26, 2011 3:48 pm
Yes.
Don't forget that you need to install Winstep Xtreme before following the instructions on the email with your license key to register it. :D
PostPosted: Wed Jul 27, 2011 9:45 pm
dude how many days before you get your license? thanks..
PostPosted: Wed Jul 27, 2011 10:13 pm
License keys are issued manually and usually sent a few hours or even minutes after your purchase.
As I told you in your other post here, it seems in the last few days there have been some problems with email from Winstep being silently blocked by some ISPs.
We're trying to fix this issue, and it would be nice if you gave us a hand too: I've just send you a test message from Winstep support titled 'Winstep mail test'.
Can you please confirm receiving it?
Thanks,
Users browsing this forum: No registered users and 56 guests
