 Post subject: Safely Remove Hardware Internal Command
PostPosted: Mon May 30, 2011 11:57 am
Jorge,
just wondering if you could add the "Safely Remove Hardware" internal command to your Internal Commands shortcut list. I built a shortcut myself, but think the addition to Winstep might be valuable, especially for those who encounter systray problems and can't see or get to the Safely Remove hardware icon.
Cheers!
Chuck
 Post subject: Re: Safely Remove Hardware Internal Command
PostPosted: Sun Jun 05, 2011 1:09 am
Just did, Chuck, thanks. Anyone else has any other suggestions for new Internal Commands?
PostPosted: Sun Jun 05, 2011 10:20 am
Thanks Jorge!
Cheers!
Chuck
PostPosted: Fri Jul 29, 2011 2:30 pm
I have an issue with this internal command. When added to my Nexus dock, it will not function properly. It comes back with the message: The 'USB Flash Memory USB Device' is not removable and cannot be ejected or unplugged. Windows 7 Ultimate 64 bit. Standard USB flashdrives (I have tried 3 different ones) and known working USB ports. This command works fine from the systray icon. Any ideas or suggestions?
Thanks in advance.
Randy-a.k.a.Wizard1956
Users browsing this forum: Google [Bot] and 60 guests
