 Post subject: Can't activate running applications
PostPosted: Sat May 28, 2011 9:55 am
Using Xtreme trial, soon to purchase this product or Nexus Ultimate (probably the latter). A problem popped up a couple days ago. While previously it was working fine, now when I try to activate a running application from the dock, the application doesn't activate. If I click the icon, it bounces as it should, then......nothing. If I click the thumbnail, just.......nothing. I have to alt+tab to access my running applications, as I have the Windows task bar and NextStart bars hidden, preferring to work just from docks.
Any idea what is going on here? Thanks in advance.
 Post subject: Re: Can't activate running applications
PostPosted: Sat May 28, 2011 1:01 pm
Open WorkShelf Preferences -> Tasks -> Advanced.
In the Tasklist Actions section, Left Click should be set to 'Bring to Front/Minimize', Right Click to 'Open Task Menu' and Middle Click to 'Close'.
PostPosted: Sat May 28, 2011 1:21 pm
That did the job. I'm liking this thing more all the time. So when are you going to stop teasing us about 11.5? It's almost 11.6, ya' know! :P
PostPosted: Sat May 28, 2011 1:32 pm
Nearly there, nearly there. :D
Users browsing this forum: Amazon [Bot] and 39 guests
