 Post subject: Combining shortcut icons and running applications
PostPosted: Thu May 26, 2011 10:11 pm
It would be great if the dock could combine dock shortcuts with the icons of the running applications; if for the running application there is no shortcut on the dock then just show the new application as another icon on the dock that disappears when the application closes (same behaviour as Seven's taskbar). This way you'll have a lot of more free space and the dock won't get full with only a few applications opened.
Also, for the upcoming feature, stacks, icons contained in stacks should not combine with the running applications. Only icons appearing directly on the dock should combine. The same for icons contained in sub-docks.
I hope you can add this feature :)
 Post subject: Re: Combining shortcut icons and running applications
PostPosted: Thu May 26, 2011 10:21 pm
It's high on the to-do list, but unfortunately it still won't be in the upcoming v11.5. Lots of other cool new features will, though! :D
PostPosted: Wed Jul 06, 2011 8:41 am
Hey Jorge, just coming back to this thread to know if you're planning to add this feature in Nexus 11.7 (as we're at 11.6 now) or when could I be expecting this feature to be added ?
PostPosted: Wed Jul 06, 2011 12:43 pm
v11.7 should have it, together with jump lists.
PostPosted: Thu Jul 07, 2011 12:31 pm
Thank you very much Jorge :)
Users browsing this forum: Google [Bot], GPT [Bot] and 32 guests
