 Post subject: Nexus not activating when Chrome is maximized?
PostPosted: Sun Apr 17, 2011 1:43 am
When Chrome is maximized and I bump the bottom of my screen, which is supposed to make Nexus pop up, nothing happens. I already Googled to find a solution, and all I really know is that the reason this happens is because Chrome acts like it is in full screen when maximized, keeping Nexus from disturbing it. Is there a way to fix this?
If there isn't, maybe in a future Nexus update, there could be a way to give the dock a list of exception programs that Nexus will appear on full screen or not. That is, if there isn't such a feature already.
 Post subject: Re: Nexus not activating when Chrome is maximized?
PostPosted: Mon Apr 18, 2011 10:46 pm
Hmmmm, strange. Unless there is a bug in the version you're using, there must be a setting that's causing it.
Are you sure that you aren't in full-screen?
See my video in the following link/thread on what's supposed to happen when you bump the (bottom in my case) Dock. And yes, I realize that I'm using Winstep Xtreme and presumably not what you're using, but it shouldn't matter in this case. As you will see, I'm using Chrome in the video.
viewtopic.php?f=2&t=4165
PostPosted: Mon Apr 18, 2011 10:52 pm
Hm. Maybe it's because I have the taskbar removed. I'll show the taskbar and see if it works.
PostPosted: Mon Apr 18, 2011 11:13 pm
Ok. BTW, to make sure you're not in full-screen, hit the F11 key while Chrome is open. It will show a brief message at the top of the screen to let you know if you're in full-screen or not.
PostPosted: Mon Apr 18, 2011 11:32 pm
I'm not running it full screen, just maximized. So, I showed the taskbar again, and the dock appeared in Chrome. I even moved the taskbar to the top (with my dock on the bottom) and the dock still appears with Chrome on. So it's the taskbar not being there.
Users browsing this forum: Google [Bot], GPT [Bot] and 64 guests
