 Post subject: Re: Nexus Dock and problems with launching games...
PostPosted: Fri Apr 15, 2011 8:16 pm
Something else on a whim: do you have Logitech's Setpoint installed on your system? If so, try exiting it for a while to see if the problem persists.
PostPosted: Fri Apr 15, 2011 9:19 pm
Yes I do have Setpoint & I did exit it, no effect I'm afraid to say. Please see attached image for focus test details.
I don't need to get a life....I'm a gamer I have lots of'em :D
PostPosted: Fri Apr 15, 2011 9:38 pm
Wow. Seems to be the Desktop modules grabbing focus! WTH?
For a quick experiment, close all your desktop modules (right click one of them -> Desktop Modules -> Close All Modules) and try again.
Also, really need to know now if the games change your native (desktop) screen resolution or not.
PostPosted: Fri Apr 15, 2011 9:51 pm
The resolution does change from my desktop setting depending on the game.
I did as you said & closed all the modules & tried opening Bad Company 2 and it opened with no issue.
Then I only activated the clock module & again tried opening Bad Company 2 and the game again lost focus, it would seem the modules are causing this issue for me.
Nexus dock runs in the background without affecting the full screen games.
PostPosted: Sat Apr 16, 2011 2:28 pm
Looks like WorkShelf is not recognizing the game as a full screen window for some reason.
You're a registered Winstep user, so apply for access to the Beta Forums section if you haven't already, please. :D
PostPosted: Sat Apr 16, 2011 3:52 pm
I do have access to the Beta section.
PostPosted: Sat Apr 16, 2011 3:59 pm
Cool, then hang on tight, new private beta should be coming out soon.
I changed the code a bit - it doesn't fix the root cause of the problem (which apparently is WorkShelf not identifying the game as a full screen window) but it will prevent the Desktop modules from grabbing focus on a screen resolution change.
PostPosted: Sat Apr 16, 2011 5:40 pm
Fantastic!
PostPosted: Sat Apr 16, 2011 6:03 pm
Yeah, it will be if the fix doesn't break something else. lol
PostPosted: Sat Apr 16, 2011 7:16 pm
Well Jorge you can count on me to test whatever you need. :D
I used to make my living off being a tester. Was with the Activision Visoneers till Activision scrapped it in 2005. I am still actively participating in a few beta programs.
I am a community skinner/mapper/modder for several PC games, mostly with the Call of Duty titles.
I am semi-retired now & find myself with time to burn lol so please feel free to put me to task 8)
I do appreciate the direct involvement & rapid resolution to the bugs you find, it shows me you are certainly a man of integrity & thats something I value. Thank you for the "hands on" for your software, I know there is no "lifetime" license but you have in myself a "lifetime" subscriber.
PostPosted: Sat Apr 16, 2011 10:37 pm
Mind if I keep you in mind, GrymmWolf?
I'm currently at university, studying a game-orientated version of computer science. A tester might come in handy sometimes (no obligations though ;))
PostPosted: Sat Apr 16, 2011 11:06 pm
Certainly :D
Users browsing this forum: Amazon [Bot], Google [Bot], GPT [Bot] and 72 guests
