Board index : Winstep Forums : General Discussion  [ 26 posts ] Go to page 1, 2  Next
 Post subject: Effect on select
PostPosted: Sun Oct 17, 2010 9:03 pm
Jorge,
What I thought would be cool is to be able to apply an additional effect on selection. I love the 'Magnify' effect(3 icons wide), but would like to apply some other effect(like 'Wind' or 'Fire') when I make my selection. Would anyone else think it would be cool?
Is something like that do-able?
Thanks,
Grouch
Windows 10 Pro[x64]
Nexus Ultimate 20.10.1154
Antivirus: Windows Defender
 Post subject: Re: Effect on select
PostPosted: Sun Oct 17, 2010 9:14 pm
Grouch wrote:
Jorge,
Thanks,
Grouch
IIRC Jorge was thinking about this in the beta. His issue with it is that low-end PC's will have trouble with rendering multiple effects at the same time without being a reasonable to huge drain on system resources (if I'm correct, that is).
Still it would be nice and Jorge could always put a warning there: "Using multiple effects at the same time can be heavy on your system".
PostPosted: Mon Oct 18, 2010 2:26 pm
I'm still thinking about this, as I would love to see it too.
I didn't implement it yet because it's not as simple as it sounds: a lot of 'tricks' are used to increase the performance of the magnify effect, so mixing that effect with others will be a little complex.
PostPosted: Thu Apr 14, 2011 2:57 pm
Jorge,
Have you given this any further thought?
Thanks,
Grouch
Windows 10 Pro[x64]
PostPosted: Thu Apr 14, 2011 3:02 pm
Looks like you missed THIS post. :D
PostPosted: Thu Apr 14, 2011 3:51 pm
Jorge,
Yup, I missed that one. Will the next release also resolve the issue of the icon getting cropped when you 'bounce when launching'?
See: http://forums.winstep.net/phpBB2/viewtopic.php?f=2&t=4115
Thanks,
Grouch
EDIT (Admin): fixed URL that was linking to a post report page instead of the topic itself.
Windows 10 Pro[x64]
PostPosted: Thu Apr 14, 2011 4:00 pm
Yes, and does more than that too: the bounce on launch animation has been much improved.
PostPosted: Thu Apr 14, 2011 4:03 pm
:D can it roll over and play dead too, now? :D
PostPosted: Thu Apr 14, 2011 4:07 pm
No, but it can make toast for you in the morning. :wink:
A great deal of work has also gone into re-organizing and simplifying the Preferences UI (especially in the free version of Nexus). Plus you can now set separate vertical and horizontal icon spacings, as well as individual background and icon transparency levels, for docks (complete with preview and all).
PostPosted: Thu Apr 14, 2011 5:49 pm
I'm drooling with anticipation!!
When do you expect the release?
Thanks,
Grouch
Windows 10 Pro[x64]
PostPosted: Thu Apr 14, 2011 5:53 pm
Never ask that question. Just... don't. :D
The answer can only be "it will be ready when it's ready". :wink:
This said, we should have a private beta for registered Winstep users soon.
PostPosted: Fri Apr 15, 2011 7:00 am
I can't wait for the beta.
On another note; how's the theme designer progressing?
PostPosted: Fri Apr 15, 2011 11:41 am
Silence...
PostPosted: Fri Apr 15, 2011 2:01 pm
Thanks,
Grouch
i'm with grouch on this one, "drooling in anticipation!!"
PostPosted: Sat Apr 16, 2011 9:21 am
Silence...
Come oooooooooon maaaaaaaaaaaaan!!! In the end, I'll end up reverse-engineering the entire config files structure and function through trial-and-error! Do something!
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 26 posts ] Go to page 1, 2  Next
Users browsing this forum: Apple [Bot], Google [Bot], Majestic-12 [Bot] and 16 guests
