Board index : Winstep Forums : General Discussion  [ 20 posts ] Go to page Previous  1, 2
 Post subject: Re: Winstep Xtremen 11.2 - Problem with switchable graphic c
PostPosted: Mon Apr 11, 2011 7:58 am
Johnny wrote:
At moment i still use the free version of Nexus, because i can change between the graphic cards without any problems.
Ah, ATI. Sigh.
Now, what is really bugging me is that the problem doesn't occur with Nexus. This is weird, because Nexus and WorkShelf share most of the code.
PostPosted: Mon Apr 11, 2011 8:11 am
I am just as clueless :(
Are there any possible solutions?
PostPosted: Tue Apr 19, 2011 12:36 pm
*push*
PostPosted: Tue May 10, 2011 9:45 pm
i find it sad to say, but i've still the same issue. A ATI driver update has not solved the problem. Unfortunately, I am very disappointed with the program and I regret it to have bought and paid for it, because it is unusable for me :!:
PostPosted: Tue May 10, 2011 10:33 pm
While I fully understand and sympathize with how you feel, I hope you realize that, being a system specific problem (Kutagh has a similar setup to yours and it doesn't happen on his system), I am unable to reproduce it here and therefore it's impossible for me to fix it.
I suggest you give the 'Art of Reporting Bugs' article HERE a read, it will help you understand better what we are dealing with here.
Since I don't have direct access to your system, the burden of finding a way to work around this issue (which might therefore also give me a clue to pin point the exact cause of the problem) falls on you.
This is not a 'show stopper' either, because, even though Xtreme crashes on your system when you switch graphic boards, you can always immediately run it again by double clicking the Xtreme icon on your Desktop.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 20 posts ] Go to page Previous  1, 2
Users browsing this forum: No registered users and 51 guests
