 Post subject: A couple of questions.
PostPosted: Sun Mar 20, 2011 6:42 am
I browsed on the FAQ but couldn't find the answer:
- How can I prevent the desktop modules from minimizing when I press Windows+D?
 Post subject: Re: A couple of questions.
PostPosted: Mon Mar 21, 2011 1:58 pm
You can't currently, sorry. However, it makes sense that you would want to do this, so I'll probably add a setting for it in a future release.
This said, there is kind of a work-around:
1. Add the 'Bring WorkShelf Forward' internal command to a dock or tab in the Shelf.
2. Right click on the icon, select 'Item Properties' and give it a hotkey (for instance, CTRL+ALT+1).
Now, if after pressing WIN+D you also press CTRL+ALT+1, the modules will come forward.
PostPosted: Wed Mar 23, 2011 6:09 pm
» More questions... I apologize if these have been answered before. I searched but could not find the answers.
»» Where are the current settings for Winstep stored? I can see them when I do a backup, but I don't know where it keeps them. Are they kept in the registry or is there an .ini file I haven't found yet?
»» Is there a specific area of the forum where we should submit bug reports?
»» This is a bug I've discovered with the new Nexus 11.2. It is recreatable on both the free and eXtreme versions. If I open a file menu (my dock is set to open folders as a menu by default) and I browse to a folder that has an identical filename as the folder, the file is not shown. The file attributes are normal and not marked as hidden.
- If I do not 'hide extensions' in Windows file explorer, the file shows up.
Windows 7 (64bit)
This is a screenshot:
http://www.screencast.com/users/ScreenT ... 437340c642
PostPosted: Wed Mar 23, 2011 11:01 pm
Some settings are stored in the registry indeed. Registry path looks like this:
Code:
HKEY_USERS\S-1-5-21-3845270527-2366638084-3310876421-1001\Software\WinSTEP2000
(you might have to search a bit).
PostPosted: Thu Mar 24, 2011 1:08 am
No searching, the instructions were clear. I went straight there, thank-you!
PostPosted: Thu Mar 24, 2011 2:26 am
Wrong key, Kutagh. Close, but no cigar. :wink:
It's HKEY_CURRENT_USER\Software\Winstep2000
the HKEY_USERS hive is used by Windows to store different user profiles, last known good configurations, etc...
Users browsing this forum: GPT [Bot] and 56 guests
