 Post subject: Help removing invisible hotspot from Dock?
PostPosted: Mon Feb 28, 2011 1:53 am
Well....I was just playing around a bit, and I added a hotspot to my dock. There is no icon at all. Basically I added the 00 Nexstart hotspot. I cannot remove this hotspot, any ideas? Basically it's like a separator on my dock. I can't do a thing with it. Help! :)
 Post subject: Re: Help removing invisible hotspot from Dock?
PostPosted: Mon Feb 28, 2011 2:27 am
i just ran across the same thing. i finally gave up and just created a new dock, move all my icons to it, deleted the old dock, then went in and set all the preferences for the new the same as the old dock.
PostPosted: Mon Feb 28, 2011 3:00 am
Blah! I am trying to avoid that. Maybe a conf file or something I can hack :) I really hope there is something else I can do, I have the dock exactly the way I want it and going through to do a reconfig does not sound enjoyable.
PostPosted: Mon Feb 28, 2011 2:09 pm
One of the fixes for the next release states the following:
* The right click 'Insert New Dock Item -> NextSTART Hotspot' method was not
working properly on docks.
So it was a bug, and it has already been fixed. How to remove the blank item from the dock, if the right click menu doesn't work properly with it either?
Drag and drop it into the Recycle Bin module (the Winstep module, NOT the Windows Recycler).
PostPosted: Mon Feb 28, 2011 2:38 pm
thanks jorge appreciate the quick reply
PostPosted: Mon Feb 28, 2011 2:52 pm
Ah ha! Thank you! :)
PostPosted: Mon Feb 28, 2011 7:54 pm
Thanks for fixing this issue. I also experienced this problem.
Janusz
PostPosted: Mon Feb 28, 2011 7:58 pm
And nobody bothered telling me, eh?! I had to get an email to Winstep support from another user to become aware of the problem. :P
Users browsing this forum: Amazon [Bot] and 70 guests
