 Post subject: WorkShelf moves?
PostPosted: Wed Apr 14, 2004 10:47 pm
Jorge, thanks for setting up a forum. I can't stand email lists.
Ok, this happens when I play a game (Halo, etc.) After exiting from the game, the WorkShelf shelf has moved an inch or two to the left. The clock etc. all stay put. I notice that all the other modules have a lock option in their right-click menus-- but not the shelf itself? I checked through the Preferences. Am I overlooking a checkbox?
Thx
PostPosted: Thu Apr 15, 2004 8:18 pm
No, there is no option to lock the shelf itself in place. Are you running WorkShelf docked to a screen edge or free floating on the desktop?
PostPosted: Thu Apr 15, 2004 8:51 pm
Free floating right in the middle of the screen.
PostPosted: Thu Apr 15, 2004 8:54 pm
^ What he said. :wink:
PostPosted: Thu Apr 15, 2004 9:11 pm
Well, does the same thing happen if WorkShelf is docked?
PostPosted: Thu Apr 15, 2004 11:00 pm
No, it stays in place.
But when I dock WorkShelf it stretches to fit the width of the screen. When I have it undocked it is not as long.
PostPosted: Thu Apr 15, 2004 11:41 pm
Uncheck 'Full Screen Width' in the Docked Options section of Shelf Preferences... then you can resize the shelf by dragging the lateral edges even when docked.
PostPosted: Fri Apr 16, 2004 12:37 am
Ok, I unchecked it. Now it does shift left (when docked) after exiting Halo.
Users browsing this forum: Bing [Bot], GPT [Bot] and 33 guests
