 Post subject: context menu colors
PostPosted: Wed Feb 16, 2011 4:02 pm
when you colorize workshelf / nexus, and nextstart neither changes the color on the nextstart menu or context menus to match. is there a setting i'm missing? if not is it possible for you to fix this in a future build? thanks
in case you need the info this is the venom1 theme
 Post subject: Re: context menu colors
PostPosted: Wed Feb 16, 2011 8:24 pm
To colorize NextSTART menus and context menus in WorkShelf, you'll have to do it from the Themes tab in *NextSTART* Preferences.
PostPosted: Wed Feb 16, 2011 9:03 pm
ok, my bad i could of sworn i checked that box. thanks for the quick reply
Users browsing this forum: Google [Bot] and 82 guests
