 Post subject: Hided the sys-tray icon and now....?
PostPosted: Sun Feb 13, 2011 11:57 am
Hi,
I hided the sys-tray icon of work shelf and now i can't open the options anymore. :(
when i click on the workshelf icon in my startmenu or in the programs folder it does not open the options. the program is useless now! :evil:
Any help here? :cry:
Thx
 Post subject: Re: Hided the sys-tray icon and now....?
PostPosted: Sun Feb 13, 2011 2:00 pm
CTRL+F11.
Not to mention that you can also access it from the Shelf and any dock (right click on the Shelf's left mini-tab -> Preferences, or right-click on any shortcut in the dock -> Nexus -> Preferences).
PostPosted: Sun Feb 13, 2011 2:49 pm
the only stuff i'm using right now are the modules. i hided all the sys-tray icons (WorkShelf and NextStart)
the only way to open any options are through these sys-tray icons, that's bad. now there is now way to open anything.
maybe you fix this problem in the next update, would be cool.
thank you
PostPosted: Sun Feb 13, 2011 4:24 pm
Hmmm... Read my reply above again, please.
CTRL+F11 - Open WorkShelf Preferences
CTRL+F12 - Open NextSTART Preferences
PostPosted: Sun Feb 13, 2011 4:40 pm
Ok, thank you...
CTRL+F11 works! ...that's good. didn't know of this function. :)
sorry for wasting your time :oops:
PostPosted: Mon Feb 14, 2011 12:13 am
Not a problem. :D
Out of curiosity, any reason in particular for you to be using only the Desktop modules?
PostPosted: Tue Mar 01, 2011 1:25 pm
sorry for the late answer...
i'm using Stardock products too (WindowBlinds)
Users browsing this forum: Amazon [Bot], GPT [Bot] and 57 guests
