Which forum style should be the default for new users?
The current default style (Winstep_Black)
33%
[ 4 ]
The new, higher-contrast, style (Winstep_Darker)
67%
[ 8 ]
Total votes : 12
 Post subject: Which style should be the new default forum style?
PostPosted: Fri Jan 21, 2011 6:47 pm
Some users found it difficult to read the default forum style for the Winstep Forums. As a result, a new, similar but higher-contrast, style has been created.
For those still not aware of the new addition, you can change to the alternate style (Winstep_Darker) in the Board Preferences section of your User Profile.
We would like your feedback on whether the new style should become the new default style or not.
 Post subject: Re: Which style should be the new default forum style?
PostPosted: Fri Jan 21, 2011 7:02 pm
If I could vote, I would have to go with Winstep_Darker.
Keeps saying "submitted form invalid" when trying to vote..
PostPosted: Fri Jan 21, 2011 9:40 pm
Sorry, uploaded the wrong file for the Darker style. Can you please try again?
PostPosted: Fri Jan 21, 2011 10:56 pm
I have to say that, on my good, colour-calibrated IPS monitor, the difference is slight between the two. However, on my laptop with its crappy TFT, the darker is a bit better. I'd like the background a little less bright, though. Well... I've already fixed that with Stylish (Firefox plug-in), but it may be better for others that can't bear bright backgrounds as well...
PostPosted: Fri Jan 21, 2011 11:19 pm
Problem was the color of the text on the background. In the alternate style the text is either black or dark blue, which should solve the problem.
PostPosted: Sat Jan 22, 2011 2:20 am
Working fine now.
PostPosted: Sun Jan 23, 2011 12:25 am
I like the new Darker style. It is MUCH easier to read now.
:D
PostPosted: Sun Jan 23, 2011 12:33 am
I like the Darker style too.
Janusz
PostPosted: Thu Feb 03, 2011 5:50 am
+1 for the newer style here too. So similar, but it makes such a huge difference! Thanks!
PostPosted: Thu Feb 03, 2011 6:02 am
Ok, I'll set that style as the default for new users. Old users can simply change to it.
Users browsing this forum: Google [Bot] and 90 guests
