 Post subject: New Feature
PostPosted: Thu Oct 21, 2010 3:28 am
Suggestions
1) In a future release it could be cool to add an auto scan to built shelf automatically (search all programs came from any local drive or certain folders/ drives, list it and select those that we want to include into our shelf)
2) Possibly add a sort option into Shelf, (select the tab, right click on it and choose "auto sort".
Thanks for this very good program !
 Post subject: Re: New Feature
PostPosted: Mon Nov 08, 2010 10:19 am
Thanks for the suggestions. :D
While I agree with the Shelf tab sort suggestion, can't say I agree with automatically collecting applications installed on your PC. I think it's just as easy (and probably simpler) for the user to add them via drag & drop.
PostPosted: Mon Nov 08, 2010 1:12 pm
Actually giving the user the option to automatically search for all programs might be nice, something like the start menu organizer.
PostPosted: Tue Nov 16, 2010 5:27 pm
On this subject - one of my shelf tabs points to various directories on my drive (videos, movies, series, etc.). Maybe it's just me, but I wasn't able to to sort them in any other way but alphabetically, which would be nice.
We are Tetragrammaton, we can do anything.
PostPosted: Tue Nov 16, 2010 6:05 pm
A bit like you can't sort Control Panel items in Explorer, either, you can only manually sort items in 'Regular' Shelf tabs (other tabs are just 'windows' into physical or virtual folders).
It's not that manually re-sorting couldn't be implemented on those tabs, but this would imply synchronizing dynamic content from folders with a static 'sort list', and you can imagine the 'mess' potential this has. Plus, what if the user decides to make a tab pointing into the Windows System folder? We're talking about a sort list with thousands of items, which then needs to be synchronized with the actual folder every time you open that tab (in case the user added or deleted files in the folder itself).
Now, adding a 'Sort by Date', 'Sort by Filesize' or 'Sort by Extension' options for folder tabs would be much easier, of course, but is it really worth it? It pales in comparison to the ability to manually re-sort items, which I think is what most users would want anyway.
Users browsing this forum: GPT [Bot] and 50 guests
