 Post subject: Faster Menu Creation
PostPosted: Mon Oct 18, 2010 3:50 pm
Hi Jorge,
Specifically, the ability to take a directory tree full of shortcuts and have the menu editor build a menu from it.
Not "add a folder item" but actually create a menu. One that I can then add separators to, other internal commands, etc.
For example, in the pre windows 7 days, I would just copy the shortcuts I needed off the start menu, add others as I wanted (to individual files), organize into folders and then just copy that tree back into the start menu.
I think you already do something like this when you build the original install version of the "start menu". This would be takingthat code and splitting it out into a separate stand alone tool.
Thanks,
John
John Strasser
Ph: 480-273-8798
Scottsdale, AZ USA
 Post subject: Re: Faster Menu Creation
PostPosted: Tue Oct 19, 2010 1:14 am
Create a new blank sub-menu of the main NextSTART menu, open it, and drag & drop your bunch of shortcuts into it.
PostPosted: Tue Oct 19, 2010 5:17 am
Ironically, I never thought of that.
John, off to play
John Strasser
Ph: 480-273-8798
Scottsdale, AZ USA
PostPosted: Tue Oct 19, 2010 8:17 am
Worked like a charm.
Thanks Jorge!
John
John Strasser
Ph: 480-273-8798
Scottsdale, AZ USA
Users browsing this forum: Amazon [Bot], Apple [Bot], Majestic-12 [Bot] and 70 guests
