 Post subject: Dreamscene
PostPosted: Fri Oct 08, 2010 5:52 am
Hi Folks,
Just experimenting and playing around (gods I love http://www.terabyteunlimited.com disc imaging),
Has anyone played around with Dreamscene? Or with the Windows 7 hack to enable it?
Thanks,
John
John Strasser
Ph: 480-273-8798
Scottsdale, AZ USA
 Post subject: Re: Dreamscene
PostPosted: Fri Oct 08, 2010 12:19 pm
"Hack"?
PostPosted: Fri Oct 08, 2010 1:33 pm
Yes, Windows 7 apparently disabled video support for Dreamscene under Windows 7, so there is an 'hack' to re-enable that support which I think has to with replacing a specific Windows 7 DLL with the Vista version.
PostPosted: Fri Oct 08, 2010 7:30 pm
i have the hack for re-emabling dreamscenes if you want it.
i uploaded the file but i'm not seeing it in my post.
PostPosted: Fri Oct 08, 2010 9:42 pm
I use Deskscapes from Stardock. Came with my Object Desktop purchase. Same thing but costs $20 separately. Lots of features, including FX and colorizing of wallpapers. Not something I use all the time though cause my desktop is usually burried under windows. Used to use their Dock but I found something better! :D
Users browsing this forum: Amazon [Bot], Apple [Bot], GPT [Bot] and 77 guests
