 Post subject: NextSTART v3.4 Final and WorkShelf v1.90 Final Released!
PostPosted: Tue Dec 06, 2005 9:18 am
Winstep Software Technologies releases NextSTART v3.4 and WorkShelf v1.90!
NextSTART Version 3.4 adds a multitude of enhancements such as Automatic Updates, Tip of the Day, improved Drag & Drop support, spring sub-menus and hotspot buttons, new sound events, ability to capture WorkShelf modules as icons into the NextSTART Startbar at user-specified sizes, automatic refresh of the Startbar Quick Launch area, ability to make Workshelf shelves from folders, improved context menu handling, ability to define how many documents appear in the Recent Documents menu, and much more!
For a complete list of changes and additions to NextSTART, please click here.
WorkShelf Version 1.90 allows you to view task icons as snapshots of the actual windows with a zoom-in on mouse over, adds task icon customization by simple drag & drop, improved task handling, new icon grow/shrink effect on mouse over, Preview button in the Advanced Skinning dialogs of desktop modules, redesigned Preferences windows, new Show Themes shelf type from where you can quickly visualize and apply themes, Browse In NextSTART context menu option for browsing folders using NextSTART menus, new Desktop Module effects and functions, ability to define how many documents appear in the Recent Documents shelf, and much more!
For a complete list of changes and additions to WorkShelf, please click here.
Download:
You can download the latest versions from the Winstep Web Site.
System Requirements:
WorkShelf and NextSTART will run under Win95/98/ME and NT4/2000/XP.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 24 guests
