 Post subject: Creating a weather dock
PostPosted: Sun Aug 15, 2010 8:36 pm
I am using the Dragon theme and I have set up several docks for different types of program.
I notice with many of the themes that a dock can be made with just the weather in it and that it can show 5-day forecast etc. How can this be done? I can only get the simple weather icon, the globe, showing just the temp and nothing else. I can find no settings to make it display more details.
Also, is it possible to add a Vista gadget to a Dock? I have tried with no success.
 Post subject: Re: Creating a weather dock
PostPosted: Sun Aug 15, 2010 9:04 pm
Hi!
That's not a dock. That's the *desktop* weather module, available when you are running Winstep Xtreme (i.e.; under Winstep Xtreme each dock/Shelf module also has a larger desktop version).
PostPosted: Mon Aug 16, 2010 7:04 pm
Thanks for your reply, I didn't realise that.
As I'm currently using the Ultimate version, I'll stop trying then.
PostPosted: Mon Aug 16, 2010 7:16 pm
There is a button in the About tab of Nexus Ultimate that allows you to upgrade to Winstep Xtreme for a very attractive price, if you're interested. :D
This said, when you mouse over the weather module in a dock or the Shelf, after a very short delay you should get a 'balloon' tooltip showing a 5 day weather forecast, and more detailed weather conditions. This assumes, of course, that you haven't disabled balloon tooltips in the Misc.Advanced dialog of Nexus Preferences.
Users browsing this forum: Amazon [Bot] and 170 guests
