 Post subject: Recycle Bin
PostPosted: Thu Nov 24, 2005 5:17 am
Help. Cannot locate the properties for the Recycle Bin.
I have the empty command on the menu, however, need to go into the file to restore an item. Thanks.
PostPosted: Thu Nov 24, 2005 6:21 pm
Spooner, are you talking about the Recycle Bin in WorkShelf or NextSTART?
Also, what do you want to access? Recycle Bin Properties _or_ the Explorer window showing you all the files in the Recycle Bin?
Users browsing this forum: Amazon [Bot] and 61 guests
