 Post subject: Newbie questions #2
PostPosted: Sat Aug 07, 2010 4:40 am
The Expensive creators.
Has Installed winstepXtreme 10.3 trial, all orderly. After installing the versions 10.6 trial , -occurs strange! Approximately in 40 minutes of the functioning , program is unloaded, all processes stop! The Display looks in the same way, either as before installing the program. After start with buttons on worker table again works approximately 40 minutes and all are repeated. On this complain already on many russian forum!
windows XP professional SP3 sistem, istalation fale dowload from click on your site.
 Post subject: Re: Newbie questions
PostPosted: Sat Aug 07, 2010 4:50 am
Which Russian forum, Ru-Board?
Are you *sure* you downloaded Winstep Xtreme v10.6 directly from the Winstep web site and not from a link provided by that board, and that you are not trying to use a blacklisted license key?
Can you please show me a screenshot of the About tab of WorkShelf or NextSTART Preferences?
PostPosted: Sat Aug 07, 2010 5:16 am
PlatoonDX
Length of service: 8 months
31-Iyul-10 15:39 (after 6 days)
[Quote]
Thank you! Like all were fixed...
[Profile] [LS]
slavyan1166
Length of service: 1 5 months
01-Avg-10 15:37 (after 23 hours)
[Quote]
beside me he why that falls asleep in a certain time,in starting start the program-once again went.Do Not know what disconnect!
[Profile] [LS]
PavelAnoxin
Length of service: 3 months 25 days
04-Avg-10 10:00 (after 2 days 18 hours)
[Quote]
slavyan1166
Beside me too most
Nobody does not know what solve this problem?
[Profile] [LS]
kondratyeva_anna
Length of service: 6 months
04-Avg-10 19:04 (after 9 hours, ред. 04-Avg-10 19:04)
[Quote]
try to add in avtostart program - beside me now is not disconnected [Profile] [LS]
slavyan1166
05-Avg-10 09:54 (after 14 hours)
[Quote] Popodrobnee possible?
[Profile] [LS]
PavelAnoxin
05-Avg-10 13:24 (after 3 hours)
[Quote]
kondratyeva_anna
So in автозапуск beside me she immediately registered. Approximately in 40 system minutes is unloaded process "WorkShelf", from the one third значек too disappears. If once again start the label "WorkShelf", that all work orderly else minutes 40 and etc.
[Profile] [LS]
kondratyeva_anna
05-Avg-10 20:22 (after 6 hours, ред. 05-Avg-10 20:22)
[Quote]
beside me mark stood "to start when start Windows", but herewith in autothread of this program in list was not. The Program was too unloaded minutes through 40, happened to to reboot. So has added the label exactly in autothread - apropos, there his(its) was not. In general, somehow so [Profile] [LS]
PavelAnoxin
06-Avg-10 19:53 (after 23 hours)
[Quote]
kondratyeva_anna
Thank you for help.
Has Removed the mark in program "to start at start of the system". Has Then copied label in file "autothread", and now all work fine
PostPosted: Sat Aug 07, 2010 5:23 am
beside me, all above-mentioned actions do not help
PostPosted: Sat Aug 07, 2010 5:29 am
Thanks for the forum thread, although the automatic Google translation is difficult to understand. I still need you to answer my two questions, though: :D
1. Are you *sure* you downloaded Winstep Xtreme v10.6 directly from the Winstep web site and not from a link provided by that board, and that you are not trying to use a blacklisted license key?
2. Can you please show me a screenshot of the About tab of WorkShelf or NextSTART Preferences?
EDIT: I've split the topics so we don't hijack CapitainKen's thread. :D
Users browsing this forum: Google [Bot], GPT [Bot], Majestic-12 [Bot] and 35 guests
