 Post subject: Clock with date and time
PostPosted: Fri Aug 06, 2010 9:51 pm
I have noticed that some of the themes have an analog clock that displays the date and time on it. How can I implement this. I apply the theme and it doesn't display. Do I need to add a command or something to make it work?
 Post subject: Re: Clock with date and time
PostPosted: Fri Aug 06, 2010 10:07 pm
Are you running Nexus Ultimate?
If you mean the big widgets on the Desktop, only Winstep Xtreme features them.
PostPosted: Sat Aug 07, 2010 3:07 am
I'm talking about an analog clock with date and time overlayed. Is that considered an extreme widget?
File comment: For example
PostPosted: Sat Aug 07, 2010 4:34 am
Yes, that is a Winstep Xtreme widget. :D
Users browsing this forum: No registered users and 82 guests
