 Post subject: NextStart Questions
PostPosted: Wed Jul 21, 2010 7:51 pm
I'm new to Winstep and have a couple of questions:
1. Can I adjust the spacing between the quick launch icons. They're really bunched up in most of the themes.
2. Some of the themes (mostly older I'd guess) display a kind of blur over parts of the tray and docked modules. Any way to get rid of this.
3. Last (for now) can I get rid of the "Do your really want to close ..." box that shows every time I exit the program.
 Post subject: Re: NextStart Questions
PostPosted: Thu Jul 22, 2010 3:29 am
1. Not for now, sorry - in v10.6 most of the skinning settings were removed from the main program and are currently being moved to an upcoming 'Winstep Theme Builder' application.
2. Any chance of a screenshot, please?
3. No, sorry, reason being that Winstep Xtreme is the type of program that you have running all the time, not the type that you exit multiple times per day (therefore this was considered unnecessary).
Any particular reason why you feel the need to exit Xtreme often?
PostPosted: Thu Jul 22, 2010 2:45 pm
Thanks for the speedy reply.
Try area screen shot attached.
Edit: One additional note, the "mask" seems to disappear after a time. It then returns if I "click" one of the modules that are attached to the tray (like to update the weather).
PostPosted: Thu Jul 22, 2010 2:51 pm
What the...?! That looks like one of the modules is 'bleeding' the background blur outside itself. I have seen this before, but I was convinced I had fixed it already. Wish I could remember the details now.
Can you remove the modules from the taskbar, one by one, until you find the culprit and then get back to me, please?
PostPosted: Thu Jul 22, 2010 3:19 pm
Definitely the weather module. As soon as I removed it, all cleared up.
Also tried with weather in and memory out, but the "mask" remained.
Jeff
PostPosted: Thu Jul 22, 2010 3:25 pm
Ok, thanks, I'll try to reproduce it here and fix it.
Users browsing this forum: Amazon [Bot], Apple [Bot], GPT [Bot] and 181 guests
