 Post subject: Not saving settings for "do not flip background for docks.."
PostPosted: Sun Jul 04, 2010 1:21 pm
Hi,
i installed free version of nexus dock 10.4 and configured it as i wish. But i see a small problem that i want to report.
I have positioned the dock on the top of the screen and i in preferences i check (enable) this option: "do not flip background for docks at the top of the screen". All works fine temporary. After i restart computer, then this option gets unchecked. It looks that nexus dock does not save this change that i did. This option always gets unchecked after system restart. How can i fix this problem?
Thanks in advanced!
P.S. Very good application :)
 Post subject: Re: Not saving settings for "do not flip background for dock
PostPosted: Sun Jul 04, 2010 2:11 pm
Please download v10.4 build 906 from here.
PostPosted: Mon Jul 05, 2010 8:02 pm
Thank you very much. Now works fine :)
Users browsing this forum: Amazon [Bot] and 44 guests
