 Post subject: url
PostPosted: Fri Sep 16, 2005 4:59 am
How do I put a url address on the menu again?
PostPosted: Sat Sep 17, 2005 5:14 am
Easiest way is: open IE showing the URL you want to put in a NextSTART menu. Click on the icon in the IE address bar and *drag* it into the NextSTART menu.
PostPosted: Sat Sep 17, 2005 5:08 pm
Not too sure what Icon in the toolbar to click in IE.
PostPosted: Sat Sep 17, 2005 5:27 pm
At the top IE has what is known as the 'Address Toolbar'. That's where you type in your URLs. The very first thing inside the toolbar, just before the URL text, is a small IE icon. That's the icon you want to drag & drop into the NextSTART menu.
PostPosted: Tue Sep 20, 2005 7:35 pm
Jorge, appreciate your reply.
However, drag and drop is not working.
Is there a way I can add the url into the menu editor? Thanks.
PostPosted: Tue Sep 20, 2005 8:49 pm
Not working?! I just did it here. Ah, wait... You're not using the latest beta, are you? It's a feature new to v3.4. You really should go download it, there aren't any known issues with it so far (knock on wood) and it is the last beta before the final release.
PostPosted: Wed Sep 21, 2005 1:14 am
You know I think Ill wait until the release.
Whats the procedure to enter manually?
PostPosted: Wed Sep 21, 2005 1:21 am
There isn't any in v3.3, but try entering the URL as a Run Program type of item. No garanties it will work though.
PostPosted: Wed Sep 21, 2005 2:33 pm
Its been done before.
I used to have a few of my favourites on the menu.
PostPosted: Wed Sep 21, 2005 2:50 pm
Works ... thank you.
Users browsing this forum: Apple [Bot], Majestic-12 [Bot] and 42 guests
