 Post subject: Hoping To Find Jorge Coelho ..
PostPosted: Wed May 12, 2010 2:41 pm
Greetings -
I am hoping to find Jorge Coelho, as I have sent a few emails to him at support@winstep.net and have thus far received no reply .. (?)
Many thanks,
Michael M.
PostPosted: Wed May 12, 2010 6:03 pm
Hi Michael! That would be me! :D
I've been replying to your messages, though. Did you check your spam folder already?
Anyway, you're still using 9.5, and the very first thing you should do is upgrade to 10.4 (no need to uninstall anything, just install the beta, which you can download from the Winstep web site, on top). Your current license key will work fine with it so no worries there either. :D
Once you have 10.4 installed, I can guide you on how to get NextSTART to replace the Windows taskbar again, which I think is what you want. I believe you'll love the new configuration screens vs. the old configuration screens in v9.5.
PostPosted: Wed May 12, 2010 7:58 pm
Many thanks Jorge ..
I have NOT actually received any of the replies you have sent .. (??)
Don't know why .. because I HAVE indeed received all your previous
emails .. (?)
Will try the new installation .. In case I cannot find the new license key ..
Is there a chance you could email it to me .. (?)
Many thanks,
Michael.
PostPosted: Wed May 12, 2010 8:35 pm
Re-sent your license key - please let me know if you got it. :D
PostPosted: Thu May 13, 2010 7:09 am
Got it Jorge .. Many Thanks !!
Is the new version then likely to cure all the problems of the NextStart
taskbar not appearing over the Windowblinds start menu and taskbar ..?
And will all my settings be HELD when the new version is installed ..?
Anyway .. will report back ..
Best regards,
Michael. :D
PostPosted: Thu May 13, 2010 7:26 am
Rainbowler wrote:
Is the new version then likely to cure all the problems of the NextStart taskbar not appearing over the Windowblinds start menu and taskbar ..?
Actually you could accomplish that via 9.5 as well (it should be just a question of re-enabling NextSTART task management) but it will be a lot easier to guide you using the much improved UI in 10.4. You'll love it, trust me.
Yes. All updates are always 100% backwards compatible.
Users browsing this forum: Majestic-12 [Bot] and 24 guests
