 Post subject: background
PostPosted: Thu Sep 15, 2005 9:35 am
Require background using Active Desktop.
How can I ensure that NextStart will load correctly using a .jpg for wallpaper?
Also,
1. There seem to be a trailing copy of a previous window that NextStart picks up in the menu.
2. How can I save/backup the menu I created?
3. When I restart the menu always wants to be on top? What am I doing incorrectly that would keep the menu on top?
PostPosted: Thu Sep 15, 2005 7:42 pm
Convert JPG wallpaper to BMP. Active Desktop interferes with basically every Windows customization software out there.
1 - Not sure I understand. Maybe video driver problems? Anyway, please post a screenshot of the problem here or send it to support@winstep.net.
2 - In your Global Preferences tab you will find buttons to Backup/Restore your current NextSTART settings. This includes your menus.
3 - Disable the Always on Top feature of the NextSTART Startbar.
PostPosted: Fri Sep 16, 2005 5:04 am
Now I would like to remove Active Desktop, however, not keen on the flash of the icons.
Now getting a flash of the background instead.
Besides removing all icons to the Recycle Bin and remaining other by registery, has anyone encountered a means of completing this (hiding all desktop icons)?
Ive got a couple of reg editors that do not hide them either.
Will complete a backup, thanks!
Also, havent completed a screen shot before so that may be a bit.
Users browsing this forum: No registered users and 37 guests
