 Post subject: Weather Module Forecast Text has Shadow Effect
PostPosted: Mon Mar 15, 2010 12:17 am
Hi everyone,
New to this forum but have used Winstep for a while.
Hmm - can't find a post about the problem I have. All of a sudden the "weather forecast" data in the weather module has a shadow effect to the text. Can't figure out how to turn it off. It's not an option in "advanced skinning options."
It's not a feature of the master theme nor have I changed themes. Just sorta happened all of a sudden. Not sure what I did to cause it, if anything.
Any ideas?
Thanks, Chris
PostPosted: Mon Mar 15, 2010 7:18 am
Not sure if this could be it, but did you change anything related to ClearType on your system?
 Post subject: ClearType
PostPosted: Mon Mar 15, 2010 2:41 pm
Jorge,
Thank you for responding. I don't know what "Cleartype" is?
Thanks, Chris
PostPosted: Mon Mar 15, 2010 4:57 pm
It's a way of rendering text. Read HERE.
Anyway, what Winstep Xtreme version, what Windows version, what theme, and any chance of a screenshot?
 Post subject: Info
PostPosted: Mon Mar 15, 2010 6:06 pm
Jorge,
The version is 9.5. I'm running windows XP Service Pack 3. I have a screen shot but am not sure how to attach it. The theme is GT3.
Chris
PostPosted: Mon Mar 15, 2010 6:57 pm
Well, in that case send the screenshot to the Winstep support address, please.
And what are you doing still running 9.5? :wink:
Assuming you're a registered Winstep user, you should get membership to the Beta Discussion forums (see first post on Annoucements forum) and get the latest Winstep Xtreme beta. It will blow your socks off. :wink:
 Post subject: Screenshot
PostPosted: Mon Mar 15, 2010 9:12 pm
The screenshot is on it's way - thanks.
I'll check out the beta once I get this quirck handled! :lol: :lol:
Chris
PostPosted: Mon Mar 15, 2010 9:36 pm
Did you change the WsWeather background bitmap to PNG?
 Post subject: Reply
PostPosted: Mon Mar 15, 2010 10:29 pm
Jorge,
I did alter the WsWeather background bmp several weeks ago. But it was in bmp format. The shadow text problem started a couple days ago, not sure what I did.
Should I unload the GT3 theme and reload it from the original zip file?
Thanks, Chris
PostPosted: Wed Mar 17, 2010 9:15 am
Ok, rename WorkShelf.exe to WorkShelf2.exe and NextSTART.exe to NextSTART2.exe (this will enable you to run those versions whenever you need to do some changes to a particular skin until the Winstep Theme Designer or whatever-it-will-be-called comes along).
Now upgrade to 10.1 and see if that makes the issue go away (I seem to vaguelly remember me and Tiggz having a discussion about this problem, but it was a long time ago, sorry).
 Post subject: Thanks
PostPosted: Sat Mar 20, 2010 10:47 pm
Jorge,
I'll give that a try and see if it works.
Thanks, Chris
Users browsing this forum: Amazon [Bot] and 53 guests
