 Post subject: Can Tips be accessed after being closed?
PostPosted: Sat Feb 27, 2010 4:33 pm
Is there a way to pull up Tips once it's closed without shutting down then reopening Winstep/Nexus?
It would also be cool if it had a back button that would allow you to go through everything in Tips and back track all the way to the beginning.
Sometimes I read something and go on to several others but then forget exactly what the instructions said, or simply need to go back to refresh my memory on a cool hint that I totally forgot because I was reading so many.
Oh, one other thing. Would it be possible to allow the tips to be copied and pasted?
PostPosted: Sat Feb 27, 2010 5:29 pm
Just right click the Shelf left mini-tab -> Info -> Tip of the Day.
As for allowing tips to be copied & pasted, good idea!
PostPosted: Sat Feb 27, 2010 11:27 pm
Thanks. :D I also replaced Hints with Tips in my original post which I now realize is the correct terminology.
Users browsing this forum: Amazon [Bot], Apple [Bot] and 137 guests
