 Post subject: Nexus not running on WIndows start-up.
PostPosted: Fri Feb 19, 2010 11:52 pm
So, I updated my Nexus yesterday (my first install was using the installer from the website around two weeks ago), now, it doesn't run on startup, even if I didn't do anything to change the settings. The checkbox in the General tab of the Preferences (Run on WIndows Startup) is ticked.
My current version is 10.1, BTW.
PostPosted: Sat Feb 20, 2010 2:18 am
When you exit Nexus, try unchecking then checking the 'Run on startup' box.
PostPosted: Sat Feb 20, 2010 10:19 am
I did that, but it foesn't work. I even checked the Startup tab at MSCONFIG, and Nexus.exe isn't on the list.
PostPosted: Sat Feb 20, 2010 2:58 pm
Open the Windows Registry Editor and navigate to the following key:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
Is there a 'Nexus' entry in there somewhere? If so, does it have any value?
Either way, for now you can always make it auto-run by placing a shortcut to Nexus in the Start Menu's 'Startup' folder. :-P
PostPosted: Sat Feb 20, 2010 3:52 pm
The problem seems to have been fixed, I unchecked, restarted, checked, then restarted again. The dock appeared after the last restart. Will check again a little later/tomorrow.
PostPosted: Sat Feb 20, 2010 4:11 pm
Damn. Err, I mean, good for you, bad for me - now I won't know what was wrong in the first place. :wink:
PostPosted: Wed Feb 24, 2010 8:07 am
Actually, something like that was happening here with the 10.1 beta 1 public
offering. Workshelf is no longer "registering" itself for startup.
Whether I set it in the prefs or from the dialog you get when exiting
Xtreme as a whole WS is not there.
I had to stick it in manually where it was before using Mike Lin's Startup
Control Panel.
No problem with NextSTART.
Marc
== ANIME SENSHI ==
Marc D. Williams
Users browsing this forum: Google [Bot] and 58 guests
