 Post subject: NextStart and Windows Error Reporting
PostPosted: Thu Feb 11, 2010 2:16 pm
This has been going on for some time. For no good reason, my computer will start making "error" sounds. The sounds won't stop until I close down NextStart. When I do that, the Windows Error Reporting (WER) icon shows up on the Taskbar (it was not visible prior to closing NS). If I then close WER, I can open NS without any problems.
PostPosted: Thu Feb 11, 2010 3:40 pm
Open NextSTART Preferences, Sound & Animations tab. Is 'Beep when a task button is flashing on the taskbar' enabled?
PostPosted: Thu Feb 11, 2010 8:35 pm
YES! Thanks. Never would have found that. What purpose does that option serve?
PostPosted: Thu Feb 11, 2010 8:36 pm
Warn you by sound that an application requires your attention. Useful if you are not sitting right next to your PC but have your speakers turned on.
Users browsing this forum: Amazon [Bot], Apple [Bot], Google [Bot] and 55 guests
