 Post subject: Desktop flashing problem
PostPosted: Mon Feb 01, 2010 11:05 pm
Hi
I have Winstep extreme and I have a problem that goes like this
Every time I open my video player everything is flashing very fast (taskbar modules etc) and also when i am moving the player or any window around ( like folders or minimizing Firefox) Is there a way in the settings to prevent that ? cause it;s very annoying.
Thank you for answering.
BTW I am using Windows XP SP 3 and i am using Winstep 8.11
PostPosted: Tue Feb 02, 2010 1:42 am
That will happen with your video player and *any* application that uses layered windows, not just Winstep Xtreme. What video player are you using, by the way?
Also, version 8.11 of Winstep Xtreme is very old - it was released back in 2008. You really should upgrade to 9.12, makes a world of difference -besides being 100% compatible with Windows 7 and 64 bit versions of Windows.
Users browsing this forum: GPT [Bot] and 29 guests
