 Post subject: Winstep Theme Builder
PostPosted: Tue Jan 26, 2010 5:45 pm
Have noticed references to Theme builder in the Forums for after 9.5- how's it going? And will it be easy to use - Thanks
PostPosted: Tue Jan 26, 2010 10:27 pm
He didn't even start writing it yet... First he's going to finish his current project, using his guinea-pigs... Then he might start on it.
Easy to use, I don't know... It's a lot of things so that might not be easy...
PostPosted: Tue Jan 26, 2010 10:55 pm
kutagh wrote:
...using his guinea-pigs...
"using his guinea-pigs", lol! :wink:
 Post subject: Re: Winstep Theme Builder
PostPosted: Fri Sep 09, 2016 12:28 pm
I'd be happy with the old one if it still works in the meantime...
As you were :)
Users browsing this forum: Apple [Bot], GPT [Bot], Majestic-12 [Bot] and 49 guests
