Board index : Winstep Forums : Translations  [ 7 posts ]
 Post subject: Chinese Traditional Translation (v16.3) (with bug reports)
PostPosted: Sat Mar 12, 2016 9:28 am
What's up?
I'm planning to finish it in this weekend. I'll update as I progress. I'm also planning to keep translating for further versions of Winstep. Please reply below for any error or suggestions.
2016/03/12 Update: The first draft is completed. I'll now carefully check every single entry, also check as much as I can on the GUI.
2016/03/13 Update: The translation for 16.3 is completed. An email is sent to Winstep Support.
P.S. I don't need a license as I already have a valid Winstep Xtreme license.
The Latest Progress
 Post subject: Re: Chinese Traditional Translation (Winstep v16.3)
PostPosted: Sat Mar 12, 2016 8:35 pm
A list of known Bugs / issues related to this translation especially:
1. I noticed that ':' is omitted on buttons. However, the Chinese version ':' is not. This results in displaying some of the ':' on some buttons.
Update: I don't use the Chinese version anymore.
2. Some words cannot be changed. I'll have to revert the changes on these names if this is not fixed...
Update: Due to the lack of response, I'm using the English name 'WorkShelf' instead (for now)
-2A: This 'WorkShelf' cannot be changed.
-2B: This 'WorkShelf' cannot be changed too.
-2C: Here, under WorkShelf Preference: The description for Modules, Settings, Advanced settings.
-2D: This has to be a bug, right?
PostPosted: Sun Mar 13, 2016 11:55 am
First of all, thanks for the detailed report and the translation.
Any chance of a screenshot displaying this issue?
Good, because 'WorkShelf' is the name of the application. It should not be translated, the same way you don't translate 'Windows'. :)
It was. Thanks for pointing it out, fixed for next release. :)
PostPosted: Sun Mar 13, 2016 12:38 pm
Seems like only NextSTART has an entry of the no colon version? I don't know how it works exactly.
This happens only on a few buttons. Other than 'More Options', I remember there're another two I saw somewhere (maybe? Don't code me on that if there're not lol) but I forgot.
 Post subject: Re: Chinese Traditional Translation (v16.3) (with bug report
PostPosted: Sun Mar 13, 2016 12:52 pm
By the way, I still cannot use drag & drop to add shortcuts on my system unless I go to control panel and change it back to English.
PostPosted: Sun Mar 13, 2016 12:57 pm
Why? What happens?
PostPosted: Sun Mar 13, 2016 2:16 pm
Why? What happens?
I don't remember if I was able to do this or not, but now when I try to drag and drop something, this appears instead.
Sometimes, it just freezes my computer.
Also, it happens quite often that this appears when I use the menu, especially for 'All programs'
Something must have gone wrong but I don't know what. Maybe Kaspersky Total Security is part of the reasons?
Post new topic Reply to topic Board index : Winstep Forums : Translations  [ 7 posts ]
