Board index : Winstep Forums : Off Topic  [ 9 posts ]
 Post subject: Backing up Laptop - help
PostPosted: Sat Mar 20, 2004 8:10 pm
My brother has a laptop running xp and the drive is only 3 gig. He wants to buy a larger drive so we need to take an image of the current drive. We have a usb adapter so we can hook it up to my desktop. The question I have is what image program will create the image in windows rather than dos?? :?:
PostPosted: Sun Mar 21, 2004 3:23 pm
In the old times what I used to do was open a command prompt window and do a xcopy <source drive>: <destination drive>: /s /e /c /h followed by a sys <source drive>: <destination drive>: , problem is that while xcopy with the above switches should transfer all the files, the sys command doesn't even exist in XP, so the drive would not be bootable.
PostPosted: Wed Mar 24, 2004 6:46 pm
Does xcopy copy long filename information? I was under the impression that using a program like xcopy would result in truncation of all long filenames.
PostPosted: Wed Mar 24, 2004 7:08 pm
Xcopy32 does. Unfortunately Xcopy32 does not exist under XP, so my guess is that Xcopy under XP does the same job as Xcopy32 under Win9x.
PostPosted: Wed Mar 24, 2004 11:05 pm
Ah, but you can go download XXCopy which is XCopy on steroids.
http://www.xxcopy.com
It's what I use for my LAN backup script and works just fine on 2k/XP. And, yes, it does long filenames without a hitch.
PostPosted: Thu Mar 25, 2004 10:04 pm
What if I want...uh, nevermind, not gonna go there.
PostPosted: Thu Apr 27, 2006 5:37 pm
You might want to try the Knoppix Live Linux CD. I think there is a good set of imaging utilities.
PostPosted: Thu Apr 27, 2006 5:46 pm
Hehe. You replied to a thread that is two years old, Paul. :wink:
PostPosted: Thu Apr 27, 2006 8:28 pm
What?!?! :shock:
Ok, is there a dumbass of the week award? I think I deserve it!
:D
Still, Knoppix would fit the bill!
Post new topic Reply to topic Board index : Winstep Forums : Off Topic  [ 9 posts ]
Users browsing this forum: Amazon [Bot] and 20 guests
