Board index : Winstep Forums : Off Topic  [ 2 posts ]
 Post subject: Suggestions, and also fix the blurring in windows 10
PostPosted: Sun May 02, 2021 1:28 am
Howdy Winstep mods and any normal person that is reading my posts
I suggest you add a blur for windows 10, that I think might work
add the acrylic and make it without color, basically normal blurring, and on top of the blurring add the dock, and because the blurring is transparent, you wont notice it
also, Fix this bug: indicators don't appear when UWP apps are opened
And add a on and off option for the fullscreen exclusion list
 Post subject: Re: Suggestions, and also fix the blurring in windows 10
PostPosted: Sun May 02, 2021 3:55 pm
This has, more or less, already been covered in previous posts - I suggest you do a search in the "General Discussion" forum as well as here. Overall, this seems well outside the Winstep 'brief' and, as far as I recall, wouldn't be possible really, given that Microsoft keep changing things in Win 10 far too frequently and generally making life hard enough as it is for Win32 apps. But this may be better addressed by Jorge - username 'Winstep' - the programmer, board admin and owner of Winstep, when he returns.
The former is probably due to the nature of UWP apps, in that notification of active status may not be passed to Win32 apps, or some such. The latter there already is - simply change the setting in the Preferences.
Post new topic Reply to topic Board index : Winstep Forums : Off Topic  [ 2 posts ]
Users browsing this forum: No registered users and 12 guests
