 Post subject: sorting the tasklist in a predefined way
PostPosted: Mon Apr 04, 2016 5:30 pm
In Windows taskbar, you can define the order in which tasks should be shown on the taskbar when running. In winstep xtreme, it seem they can only be sorted in alphabetical order? I would really like to give some specific defined order (first chrome, then .... and in the end everything related to outlook).
--- Mats ---
 Post subject: Re: sorting the tasklist in a predefined way
PostPosted: Mon Apr 04, 2016 5:37 pm
The NextSTART taskbar still separates User Pinned/Quick Launch icons from the list of running applications (task list).
You can re-order Quick Launch icons (which are really hotspots under NextSTART) anyway you want, and any changes you make will stick between sessions.
You can also reorder running applications at will by dragging the tasklist buttons, but, because those are dynamic, changes will not stick between sessions.
Users browsing this forum: GPT [Bot] and 57 guests
