 Post subject: Workshelf moves to wrong monitor
PostPosted: Fri Mar 18, 2016 6:41 pm
If I try to add a new tab into the Workshelf, the workshelf moves to the wrong monitor. My monitors are arranged as
23
14
in Windows and as
12
34
in Winstep. The Workshelf is in the bottom of Monitor #1 in Winstep but gets moved to the bottom of Monitor #1 in Windows.
Steps to replicate:
o Right click Workshelf bar
o Click Add New Tab in popup menu
The Workshelf moves to the wrong window when the Add New Tab box pops up.
 Post subject: Re: Workshelf moves to wrong monitor
PostPosted: Fri Mar 18, 2016 6:54 pm
Is the Shelf docked or 'floating'?
PostPosted: Fri Mar 18, 2016 6:58 pm
Docked at the bottom.
PostPosted: Fri Mar 18, 2016 7:02 pm
Forgot to ask: what is your primary monitor in Windows?
PostPosted: Mon Mar 21, 2016 5:49 pm
The upper left monitor is the main display. Windows reports it as #2 while Winstep reports it as #1.
Users browsing this forum: Majestic-12 [Bot] and 25 guests
