 Post subject: Help -- unhide Nexus via keyboard (or whatever)
PostPosted: Fri Feb 19, 2016 8:29 am
Hi,
I set Nexus to display on another monitor, but now it is on the wrong (inner) monitor border and I can't make it appear.
Pls. help how I can manually unhide Nexus, or how to enter the settings dialog whithout Nexus being accessible.
David.P
 Post subject: Re: Help -- unhide Nexus via keyboard (or whatever)
PostPosted: Fri Feb 19, 2016 4:43 pm
Press CTRL+F11.
PostPosted: Fri Feb 19, 2016 5:30 pm
Thanks!
PostPosted: Mon Feb 22, 2016 8:05 am
CTRL+F11 doesn't work :(
I might have changed it because that is usually my shortcut to making a screenshot :o
Any other way -- e.g. like editing the config manually?
PostPosted: Mon Feb 22, 2016 8:41 am
What about the Nexus system tray icon? Did you disable that too?
PostPosted: Mon Feb 22, 2016 9:01 am
Probably I did, years ago...
At least I can't find an icon belonging to Nexus.
PostPosted: Mon Feb 22, 2016 9:17 am
Nice way to shoot yourself in the foot. :wink: :D
Run Nexus with the 'setup' argument. Either by opening a command prompt window, navigating to C:\Program Files (x86)\Winstep\ then launching 'nexus.exe setup' from there or by temporarily changing the shortcut used to execute Nexus.
PostPosted: Mon Feb 22, 2016 9:32 am
Thanks. Actually installing the latest version did it because there obviously have been improvements regarding mouse detection at the screen border.
All set now,
David
Users browsing this forum: Apple [Bot], Google [Bot], GPT [Bot] and 53 guests
