 Post subject: Nexus question
PostPosted: Tue Dec 29, 2015 7:42 pm
I've been trying out toolbar programs for a few days, and they all have this same problem. The main thing I want the bar for is to launch bat and vbs files that I've created. These work fine as a desktop shortcut, or on the regular windows toolbar, but it seems all 3rd party bars make an error about "windows not being able to find a file". These files are always found when the shortcut is placed anywhere else on the system.
I've tried running the bats and vbs files as admin, and running the taskbar progs as admin, but same errors.
Any idea what is causing this & how to fix?
 Post subject: Re: Nexus question
PostPosted: Tue Dec 29, 2015 8:36 pm
Strange. Where are the batch and vb script files located at?
Have you tried already moving/copying one of them to a different location in your hard drive? Say, C:\Temp\?
PostPosted: Tue Dec 29, 2015 8:59 pm
Found it. In the Nexus interface for each item you can set to run as admin, and that did it.
PostPosted: Tue Dec 29, 2015 9:47 pm
Goes against what you said ('ve tried running the bats and vbs files as admin') but glad you sorted it out. :)
Users browsing this forum: Apple [Bot], Bing [Bot], GPT [Bot] and 53 guests
