 Post subject: Windows update killing Nexus Ultimate
PostPosted: Wed Dec 19, 2018 2:36 pm
I've been using Nexus Ultimate for a very long time and have always been completely satisfied with the performance. A couple weeks ago my system had the Windows 10 update to 1709, the Fall Creators Edition. Ever since that update Nexus has significant issues.
There is a very long delay while Nexus is originally loading after login. It begins to load then just stops. During this time the rest of the system is active. Eventually Nexus finishes activating and can be used. I use multiple docks, not a shelf. If I have not accessed a dock for some time when I bump the screen edge there is a delay for several seconds before the dock unhides.
Any thoughts on what the cause of this might be or what I can do to resolve it?
Randy
 Post subject: Re: Windows update killing Nexus Ultimate
PostPosted: Wed Dec 19, 2018 5:59 pm
Perhaps it's related to the dock content? Do you have any shortcut in it located in a network drive?
One thing you can try: make a backup of your settings (Preferences -> Advanced tab -> Backup) then reset everything to factory default (Preferences -> Advanced -> Troubleshooting Options -> Reset Everything)
See if the problem persists.
PostPosted: Wed Dec 19, 2018 6:57 pm
Excellent suggestion. I will do that and see what happens.
Thanks very much.
Randy
Users browsing this forum: Google [Bot] and 10 guests
